Originally Posted By: MolaKule
Quote:
that statement is somewhat incorrect.
THEIR GEAR OILS do.
their MT oils are formulated differently.
they also have a GL-4 full syn. for regular MT's
and a GL-5 for hypoid diff's and combos like subaru/porche front axle/mt
they both have the proper FM's for use in a MT vs a friction reducing brew designed for a regular non MT application.
The redline for this application would be MTL (IIRC)
MT-90 would be too thick.
they also have a newer GL-4 70w80 MT fluid
and a GL-4 75w85
Their D4 ATF is also good and provides a GL-4 Level of protection.
He is correct. The Redline Manual Transmission lubricants have high levels of Anti-Wear Additives (AW).
You're thinking of Extreme-Pressure additives (EP) for differentials.
If your Operator's Manual says you can use the GM Synchromesh fluid, then the GM Synchromesh, Pennzoil Synchromesh, the Redline MTL70W80, and the Amsoil MTF all have the correct viscosity and AW package.
Do not use D4 ATF.
The only exception to that last line
might be for winter time use at or in the Arctic Circle.
