2001 Chevy S-10, 2.2L 5 speed. Transmission fluid was checked last month and is full and clean. When accelerating in first up past 25 mph (sometimes after 20 mph), there is a sound like a metal spring whirring around, rather high pitched. Sounds more like a circular metal piece that is part of the assembly rubbing on something, not a loose chunk bouncing around. Only comes in at higher rpms also in second gear sometimes, prob never take 3,4 or 5 high enough to hear it. What could it be?
I am thinking to change out fluid and install Redline MTL. No thicker that stock fluid, but more antiwear, maybe help?? Can't hurt, may help, at 78,000 miles not a bad idea to change out fluid anyway, no?
