Last Tuesday I went to start my car (after I had driven for 12 miles about 2 hours before), and it gave the starter quick spurt of power and failed. I tried again afterwards and it started after a few cranks. Since then I've used it most every day since then and it has started strong and quickly. This past Tuesday it did the exact same thing, failed on the first try, barely worked on the second and then also worked perfectly an hour later. Does this seem like a bad battery situation?
The battery is the original factory ACDelco, and the car was manufactured September 2006 so I assume it is that old.
