Making Bob proud
SD - South Dakota
You all should be proud.
We had a snow storm over night so I got up at 4:30 to go out and move some snow before my wife had to do chores. There was about 6" and I thought she'd appreciate not having to walk through all the snow.
So, it's upper 20's outside and I walk out to the old plow truck. It's a 83 Chevy K20 with a carbureted 350/700r4. I open the shed doors, turn the key and fire it up. I blipped the throttle a couple times to make sure it was ready to go, dropped it in gear, and started plowing snow.
no warm up .. no delay .. just right to work.
the only bad part about doing that, and why I usually don't, is that the gear changes from forward to reverse are very harsh when the engine is at high idle. It engages hard enough to rattle everything in the truck, so I like to get it off high idle before plowing, but at 4:30 ... I cared less than normal.
20 minutes later I was back inside drinking coffee.
FWIW, the sump is filled with Mobil 1 Advanced Fuel Economy 0w30 from 2 falls ago. Not even a hint of darkness to the oil yet, and I'm only now down to the point where I might add a half-quart.
making Bob proud!
I would have done my wife's chores for her. To be honest, I have no idea what kind of chores would need to be done outside in the winter but I'd do them for her.
It takes a full 5 minutes of high idle for the engine to have enough heat to come off high idle. At 4:30 I didn't feel like waiting. The choke is tuned correctly and it runs fine when cold. Why wait? Other than slamming into gear at high idle, the truck runs fine when cold.
As to doing her chores, I could, but it involves handling hay, to which I am extremely allergic. Just throwing it over the fence and I cant breathe for about 3 days. I put in the round bales and keep the equipment going she does the hand work. Which, IMO is fair since if it were up to me, id get rid of every single horse and raise a few head of cattle instead.
The truck typically gets run once a week when I put in round bales because it is parked in front of the tractor in the shed. But I do keep the truck and the tractor on a battery maintainer 24/7 during the winter.
I often only let my '85 kick down off the highest set and run 1-2 mins. more before pulling away. Ditto to somebody else that understands the old stuff can be just as consistent and dependable as the new, it just takes a little sense to keep them going.
I'm sure the farmers on the board chuckled...
After I posted that, I was thinking maybe the wife had to feed the chickens or something. Yup, not a farmer.
