Here is my cheapo Troy-Bilt 5550 Watt Generator. I bought it in May 2004 (just before Florida had 4 hurricane hits in the summer.) Has about 350 hours on it. First hurricane, house had no power for 10 days. Changed the factory fill after 2 straight days (48 hours). Changed again after 3 days, then again after the mains were restored. Only saw B&S warranty certified HD30 conventional oil. A month later, power out for a week (7 days). Oil changed once during that spell. Again B&S oil. the next 2 'canes we had power out for about 8-10 hours. Need the genny as our septic system has an effluent pump. It ran a 28 cu ft refrigerator, microwave, little 6K BTU window A/C unit and other things during that time.
At least 2 times a month, I run it with about a 25 amp load. Starts on the second pull. First pull is a slow pull to get fuel to carb. Second is full on.
This is only a 10Hp OHV standard Briggs engine with splash/slinger lube.
It has only seen mineral based oil. Mostly B&S oil or Rotella. Current fill is Pennzoil HD 30 wt (I just dumped the rotella after 48 hours as My FIL used it on a camping trip a few weeks ago). Has never seen any oil treatment. I do run SeaFoam or Sta-bil in the gas, as it sits for long times. I have also dumped old 40:1 2-cycle oil mix in it's tank. Has never had any additives in the crankcase.
I took these pics yesterday, as I was getting her ready for Hurricane Season. Everything looks dry, as it was sitting for a week. I pulled the rocker cover off to check valve lash, which you have to do cold. Lash was still within spec.
Just pulled the cover.
Rockers.
Rocker cover.
Rockers.
Rocker cover.
