Originally Posted By: motts
I recently got a Mahle oc 479 for my '02 V6 Camry only to find out the psi rating is 30. My Camry specs out for around 10 psi.. should I use it?
Are you talking about the bypass setting? If so, no, do not use a filter with a bypass setting 20 pounds higher than the one intended for your vehicle even if it otherwise "fits".
