Magnefine Vs Remote Filter Mount
FL
In the future, I plan on installing some type of filter for my automatic transmission. I read all good reviews about the Magnefine and that appears to be a good option. But after seeing how small the Magnifine is, I would prefer a larger filter for an increased amount of holding capacity. I would be able to spin off the filter can and replace it rather than disconnecting ATF lines every time. I would also have a greater variety of filters to chose from, P1, M1 Bosch D+, etc. So members of BITOG what do you say, would you install and mount an external filter or go with a Magnefine?
Probably the biggest problem with the spin-on is where do you mount it with today's crowded engine compartments? If you can find a place to mount it, go for it. The setup costs more up front, but the filtration can be better, depending on what spin-on filter you use. Spin-on filters are usually cheaper and easier to change and have way more capacity. Probably no reason to change more often than 50-100k miles. You can add strong magnets to the outside of the filter if you like.
That being said, I usually use a magnefine or spx and they do an outstanding job.
The remote mount and related hardware will run you $40-$50. The Magnefine will run you about $20 and require (maybe) a couple of clamps. I don't know how much the newer models run. They appear more suited to the hard line installations.
Hydraulic mounts are the cheapest. They're a much better deal than engine oil remote mounts. The filters are usually more expensive, but tend to be finer.
A BP80A with an EaBp90 is about the cheapest bypass setup to put on a trans. It too has space requirements, but runs maybe $70 installed/delivered (some hose barbs, hose, and clamps required).
I have a remote ATF filter unit just like the one in the link on my suburban. I mounted it just below the fan shroud so it 'sees' plenty of air, kind of acts like a bit of a cooler (I have a front mount trans cooler too). It makes half capacity drain refills a breeze, & I use a Baldwin filter for durability. I have had it on there for more than 6 years, my fluid stays clean between D&R's, the transmission still shifts like new. I have nearly 200K miles on the all original everything.
Originally Posted By: CharlieJ
I am considering just buying one of these oil filter mounts: http://www.jegs.com/i/Trans+Dapt/969/1028/10002/-1 and buying all the hardware (hose, clamps, fittings) separately. It says it uses a FRAM PH8A filter. What is the cross reference for a P1? Or does anyone have cross reference list?
That's not too bad. The Jeg's $9.95 handling fee makes it a $20 deal. From there you only need a couple of reducer bushings and some 5/16 or 3/8 hose barbs (depending on the size of your line) and some cooler hose/clamps.
Yes, the PL30001 is the PureOne number.
The price of this went up a tick probably due to currency crash. It can fit one automotive filter for the Jag/Lincoln app, but the spec'd filter is finer. The mount itself has a bypass valve.
http://www.northerntool.com/shop/tools/product_12006_12006
