Originally Posted By: Johnny
Anyone know anything about the new oil filter adapter that Magnefine has out. It's called FORCEFIELD. Looks like it screws on the engine, then the oil filter screws on to it. Looks like one big magnet.
Funny you should ask!
I have two mounted and have taken "before" oil samples for particle count tests. One's on my F-150 (5.4L w/18K miles) and the other on an 8300 hour Neuss D358 diesel in a tractor. Both were installed with dirty oil. The tractor had about 45 hours and on year run time on a 2-year. 100 hour OCI. The Ford F-150 is 7200 miles into a 7500 OCI. I figure the time to see a dramatic change is when the oil is good and dirty. The Ford has a Motorcraft filter and I 've never seen the micron rating on it... but think it's a fairly efficient filter. The Neuss has a Wix with a 25um nominal rating. I'll have results back on the F-150 in a month or so, but the tractor (likely the most dramatic test) won't be till the fall. We'll see. Subjectively, I can say they look nicely put together (typical of Aussie built stuff). Easy enough to install.
As to the Magnefine, it's a 35um filter (nominal) with 49 square inches of media. I have been told by the guy who invented the thing that it will catch 99 percent of all ferrous particles because of the flow director at the magnet. I have seen some dramatic reductions in contaminants in two trucks with these babies, so I'm sold!
