M20 Purolator Guide (Oversize)
Trinidad
M20 Purolator Guide
This is a listing of Purolator oil filters with a M20*1.5 threading that I have come across in my research for the biggest filter.
Hope this help you guys out.
Purolator Height O.D. Relief Valve PSI
L10193 3.19 3.70 15-18
L14610 3.52 2.69 14-18
L14612 2.93 2.69 14-18
L14619 3.75 3.69 8-16
L14459 2.95 3.15 12-15
L14460 2.95 3.15 20-25
L20073 4.74 2.98 12-15
L20253 3.75 3.76 8-16
L20287 3.75 3.76 20-25
L20290 4.22 3.81 8-11
L24458 3.94 3.15 12-15
L30165 4.74 2.98 25-35
L30251 6.70 3.15 32
L34480 5.45 3.50 15
Fantastic...I just put a 20073 equvilant napa gold 1347 on my car yesterday as I had a couple on the shelf, stock is 14459. As it turns out though the length is a bit to long and I need a smidge shorter filter for the next change.
I could really use some 24458's but I have found none in my area.
Don't forget, you don't HAVE to use M20x1.5 filters
I've changed the filter threads in my '97 Soob so I can run 3/4x16 filters (Motorcraft FL400S and FL1A for example). I describe the very inexpensive (about $8 less than 2 years ago) part here http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=6;t=001434#000000
Dave
PS, Purolator has discontinued the 24458.......
I would recommend double check before jumping on any oversized filter posted above. For instance actual L20290 Relief Valve PSI 13-19 and not 8-11.
LT4Vette, yes, but the FL-400 and it's equivalents are easier to find in my area AND Purolator doesn't make a PureOne version of it.
Besides, how many other Subarus in the world are running around w/ a "Ford" filter?
Dave
