Patman,
Thanks. Your plan sounds like it would yield more reliable results than mine.
Mobil's additive package for the Trisyn never impressed me, but the Supersyn seems to be pretty good. 80ppm of moly (almost as much as Schaeffers) seems to help. You'll recall that the wear metals on my VW were basically cut in half after going from trisyn to supersyn, and all other parameters held constant (same weight, miles, driving condtions, mileage, etc.).quote:
Originally posted by Terry:
buster,
I like both oils, Amsoil for cold weather operations 5w-30/10w-30 non group 3 oils.
I like Mobil 1 if doctored some to boost Boundary and Mixed lubrication.
Both have their strengths and weakness's, use the analysis to tell how either work for you, in your car.
While I will agree that SuperSyn is showing excellent oil analysis results, I just want to point out that Schaeffer oil typically has about 170ppm of moly, while Mobil 1 is 80-90, so it's not quite the same amount. Plus Schaeffer oil also adds Penetro, which has similar properties to moly.quote:
The used oil analysis numbers I've seen put Schaeffers around 120ppm and Supersyn around 75-80ppm. Not sure about virgin numbers. Clearly Schaeffers uses more, but I don't think it makes a huge difference. I'm just glad Mobil put a decent amount in there and that it seems to work well.quote:
