Originally Posted By: B320i
As I said when we discussed the million-mile BMW E30, assuming it was on a rolling road at 65mph for a year isn't accurate. In the case of the BMW test in the 1980s, the million miles in 4years theory doesn't add up right assuming all-highway running.
They mention the test ran for 4 years, and a million miles. People here are questioning whether the test was valid, because they assume the engine was running highway miles and was generally warmed up the whole time.
However, if you put the math together (failing to take into account the 50K durability test done in the beginning)...
1,000,000 / 4 = 250K annually
250,000 / 365 = 684 miles daily,
Which, if you /24 to get an hourly average = about 29 mph.
Mobil's video states the vehicle was running between 45 and 85mph during their extended test. These figures suggest the car was only running around half the time the test took... Could this suggest a daily cold-start? Or downtime?
Their test are performed outside under cover. They do vary the speed and load placed on the engine. My own experience doing 10K OCIs with M1 oils for the last 39 years, has produced very clean engines, no sign of engine wear or increased oil consumption, and never had a lubricated part replaced.
