Wear that is collected by the oil filter, and anything outside of the range of the analysis, aren't seen. Trending is needed for 'consistency'. Comparison is also needed. UOA is just a tool. Just because it doesn't show wear, doesn't mean the engine isn't grinding itself down. Nothing worse than **** good UOA's and the engine fails from part failure, or sludge/varnish. UOAs aren't continuous and just a single point in time, hopefully repeated enough for usable data. My drainplug and/or filter magnet will show more than a UOA.
In this UOA, your failure is the visc and fuel. And, that fuel is needed for your tune... boost/compressionratio/safety!
BTW, last I talked to my colleagues employed by your automakers, they are definitely wear testing with excessive fuel. This implies plenty. Instead of solving a problem, they are working around it. They were definitely caught with their pants down. Consumers aren't paid for their R&D by the automaker!
4000 miles is a short interval. You could shorten it more, but depending on miles driven per years, a 3k interval could be a hassle. The other option is a 5w30, then a higher hths 30, and finally 40 grades.
Don't wait for parts failures to decide on changing grades. Once you went for the tune and upgrade, the OE oil grade and interval recommendations are null and void. The local waltonmart and autopart stores have a good selection of 30 and 40 grad euro/hdeo oils. Time to go thicker.
Are you monitoring oil temps and/or PSI?
