A friend with a new Porsche Cayman has been changing his oil religiously after every 2 track events and taking samples for analysis. Everything in the analysis has looked good--minimal wear, low fuel %--except falling out of grade to the 100 deg. C viscosity rating of 11.0-11.3 in only 2500 miles between oil changes.
IIRC, 40W specs say that the minimum in this weight is 12.5;M1 0W-40 is rated about 13.5. Porsche specifies a minimum oil weight of 40W (0W/5W-40 oils).
Should this owner be concerned how this oil is protecting his engine if it falls to this level of viscosity when hot?
thanks for any help.
