LuK clutch RepSet kit reviews
Luk is good brand for Euro applications. As long as the Corolla set isn’t some white box rebrand, I would use it.
It's only one data point, but there's a LuK clutch set in a car in my driveway with a lot of trouble free miles on it since it was installed.
Neighbor has one running around in a K3500 Chevy that he would haul 3 bales of hay on multiple times a day. I sourced the parts for him when he had to replace it. I have one in my Ranger(about the easiest application for one) and have absolutely no issues with either one.
Luk is good stuff. When I put the clutch in my Mazda the internet world seemed to think Exedy was the best for it so I went with that. Has been a good clutch.
LUK or Sachs is all I will use when I'm doing a clutch replacement and getting an OE part is usually prohibitively expensive.
As a comparison, earlier this year I changed the clutch and CSC on my Wife's Dacia. The LUK kit I purchased was £160. The OE kit from the dealer was £500.
Many of the clutch kits sold by the major brands(ZF Sachs and LuK) more than likely will rebox a PHC Valeo unit for Japanese/Korean cars. Else, either LuK or Sachs should work.
Does anyone make a bad clutch?
OE dual mass flywheel clutches are notorious for early and sometimes catastrophic failures and expensive. This better mouse trap has been redesigned more times than I have had hot dinners yet they still come apart internally. When replaced with a regular clutch and flywheel it is the end of the problem.
Some Porsche and BMW cars use these and when tuned can have dramatic fails, a dual disc is a permanent albeit pricey repair until the disc wears out.
I'm sure there are lots out there with good service- I avoided them and ended up with Sachs which was a reboxed Valeo. Look hard for Aisin kits.
And on some of them if you install a SMF flywheel you'll destroy the transmission. 🤷‍♂️
I have seen more DMF damage transmissions than SMF when they come apart. Doing a conversion may be an easy off the shelf job like many VW or possibly a pricy job like a M car or Porsche that requires a balanced flywheel plate and disc assy.
The whole point of a DMF is to reduce vibration being transferred to the transmission input shaft, with a properly well balanced SMF unit there is also minimal vibration, the torsion plate in the disc is taking up the shock loading just like the springs in a DMF. High quality and properly engineered parts make a world of difference
https://www.autoserviceprofessional.com/articles/8950-porsche-dual-mass-flywheel
