Has anyone had any experience with this product?
I was considering trying some, although I can't find any locally.
Quote:
DURAGLOSS Aquawax is the best.
and it's NOT a quick detailer, it's a last step product... Using it as a QD may marr your paint.
Before I tried Slick Mist I would have agreed with your statement.
Perhaps you should try a product before passing judgment on it.
You are correct AW is not a quick detailer and neither is Slick Mist.
Slick Mist is a polymer sealant it is intended to be a last step product but it is so easy to use that many are using it as a quick detailer.
I still have over a gallon of Duragloss fast clean and shine and a gallon of AW and will use it on my daily drivers.
The DG 105 is one of the most durable products on the market and the AW will extend the life of the 105 but their is a reason that so many use SM at car shows.
When you must make your car look as awesome as possable and you only have a short time to do it and you may be doing it in the blazing sun nothing does it better than Slick Mist
I think that AW is more durable so it depends on what you are looking for. AW is much harder to apply and remove especialy in the sun.
Like I said I use 105 and AW on all 7 of my daily drivers and yes AW is easy to use but if you try to use it in the sun or use the FC&S in the sun then try the slick mist you will know what I'm talking about.Quote:
"AW apply and remove"? I have not tried Slick Mist. Now I want to. But, what's hard about applying/removing AW? Just spray on while drying your car (with Absorber or MF towel). It might add 2-5 minutes to my typical drying routine. The next day you'll be amazed if you have metallic paint.
