Lucas ATF additives?
I find Lucas trans additive very useful, and their fuel additive very useful AND their UCL additive very useful.
Well, more like I find their bottles make the best funnels. Never used any of the additive.
Originally Posted By: engineer20
My taurus transmission doesn't shift smoothly and it is nearing 80k. Should I put Lucas or lubeguard in it or will it hurt?
I would probably drain the entire contents of the pan and replace with 5 quarts of Lucas and 6 bottles of lubegard Platinum.
I agree except I'd use seafoam transmission additive for a couple hundred miles then drain and fill with maxlife.
And use a synthetic transmission fluid. The viscosity index will be higher which means better fuel economy at start up while the fluid gets up to temp.
Repeat the drain and fill cycle every week until the fluid looks like new in the transmission.
Is lubegard platinum the one that comes in the red bottle? I saw they also had a friction modifier product and another one saying ATF protectant, which one is being talked about and which one should I use? The taurus had a transmission fluid flush at 55k
Lucas really does keep your transmission cooler, it just might take a bit for the thing to grenade itself after you dump the garbage in.
Boom, cool transmission.
The Red bottle is Lubegard "red"... Duh
The Platinum is the silver bottle.
Now that i think about it i would probably skip the lucas all together and add all Type F fluid with the Lubegard platinum!
