I see a lot of fuel additives claim to reduce ring / bore wear. Does FP claim to reduce wear at the ring / bore interface, or is it primarily just a cleaner / combustion enhancer?
No on the first and no on the second. The reason for the MolaBrew was to lower FP's ignition temperatures in Winter.quote:
Would adding a dab of ATF to the FP help with upper cyl lubrication?
Is the Mola brew of FP and Neutra a better UCL than FP alone?
http://www.lubecontrol.com/id19.htmlquote:
i.) “Longer Injector Life.” Yes. By not only cleaning the injector with Fuel Power, but lubricating it as well, the injector will stay cleaner and continue to produce a more optimum spray pattern, resulting in increased combustion efficiency and less injector wear.
The bulk oil from the sump lubricates the rings, cylinder, and valve guides. [/QUOTE
How DO valve guide get lubricated? A controlled leak through the stem seal? What keeps the oil from coking on the exhaust valve stem?
It depends on head design.quote:
Detergent/Dispersant, low volatility of oil, tight fitting bushings reduce drip down.quote:
