Lubegard Engine flush
Auto-rx would be better. But if you insist on a solvent type flush fogetaboutit.
I have used Amsoil flush many times in the past. I am sure it works OK. I can't see Lubegard being much better, but I don't know anything about it. It appears to be a typical solvent flush.
But auto-rx is a much better chemistry.
LUBEGARD® Engine Flush
* Cleans Gums, Varnishes & Deposits
* Frees Sticky Valves & Lifters
* Improves Oil Circulation
* Will Not Harm Seals & Gaskets
* Does Not Contain Harmful Solvents
Sorry, but I don't see AutoRX as a much better chemistry. There is nothing typical about Lubegard products.
Regardless of which product you use, follow the directions.
Quote:
Quote:
Everyone yammers about this stuff. No one tries it. I say give it a shot and report back.
I have my doubts but still.....
Do tell..
Nothing mystical. The Lubegard Engine flush is just not in the engine for very long. I'd be at least tempted to do the idle thing. Then shut it down and restart the car the next day to repeat the idle process, sort of a longer soak thing.
