What I find amazing is that you can condemn an entire brand's powertrain engineering based on what is essentially one transmission here: the AX4S.
I said the AX4S was the specific trans I had in mind. The entire A-series trans line, and pretty much every single FWD auto they made was a turd. If you really want me to go into, I will definitely do so, but I hoping you will do a little research first, and not make me have to write a lengthy post about it all.
At that point, all you have left is their RWD autos, and we just covered the situation with its volume leader in the RWD sector.
Quote:
You've been tossing around statements on this board that Ford can't engineer transmissions, Ford overloads transmissions....etc but they all appear to be based on one freakin' transmission model here. Did one fail and cause you to lose a loved one on the way to the hospital or something?
I will definitely be making a mental note on how quickly you jump to conclusions. You might have noticed by now that I have owned at least 3 Ford vehicles, and seem to have some very specific knowledge on Ford vehicles, and their issues. Getting a clue yet? My family is a Ford family for the most part. It's hard not to know what's wrong with Fords when there's so [censored] many of them around, and you are informed of and asked to research and diagnose all of their issues. LOL
Quote:
- GM has made some pretty poor transmissions in the past.
- Ford has made some pretty poor transmissions in the past. This would be one of them.
- Honda has made some pretty poor transmissions in the past. My MIL owns one in an Odyssey.
- Chrysler has made some pretty poor transmissions in the past.
But they've all made some pretty bloody good ones too. And aside from the converter shudder, the 4R70W, AOD, and AOD-E were generally pretty good transmissions (I have one with coming up on 400K on it).
Regarding Jerry, yes, the J-mod is a popular upgrade for the 4R70W, making the shifts faster and firmer. And Ford SHOULD have upgraded the slushbox for Mark VIII use in this manner from the get-go. I can agree with you there. But a quick look to guys like Lentech will show that the issues in this application weren't because the transmission was junk or poorly designed. There were things that should have been upgraded/beefed-up that weren't initially. These items were fixed later.
You do realize that everything you just listed are engineering/design issues, right? That if they were well engineered, they wouldn't have had those issues in the first place? You seem to have taken my statements to mean that every single component in the transmission was total and utter trash. Not the case. But it is important to remember that even the most notoriously [censored] transmissions only end up that way because of one or two poorly designed parts. So yes, if you have a transmission with a few poorly designed components, it is a poorly designed transmission. Aside from maybe some 1950's Lada that might have had a plastic gearset, cardboard clutches, fiberglass case, and paper/origami valve body, I can't even imagine a notorious transmission that just has every single one of its parts complete garbage.
Ask anybody who signed off on tens of thousands of dollars of debt on a brand new Ford just to end up with shudder, roller clutch transmission death, slipping under 30k miles, or any of the other issues those transmissions gave if the transmission was poorly designed.
Quote:
Your criticisms of Ford here apply to any auto manufacturer, so if you have a VALID reason for singling out Ford, I'd be interested to hear it.
There's no doubt about that. I think Mazda has a worse record than Ford for screwing up ATXs. They're so bad, they even screwed up good ATXs that they bought from other companies.
However, the reason why Ford always gets the honorable mention when it comes to bad ATXs is because of experience. It's one thing to read about how bad a certain marque's transmissions are, and quite a different thing to know it firsthand.
If it's worth anything, I think Ford had the greatest turnaround where this matter is concerned. Semi-synthetic fluid, giant air/fluid transmission coolers, large capacity systems, combining forces with GM for the new 6SP auto, in-depth revisions of bad components, etc. None of our current vehicles have any transmission issues, and we really like Ford vehicles overall despite all of those nasty transmissions and bad diesel engines they sold us. Warranty service was never an issue. They knew what they did, and they were never shy about fixing it, so whatever.
