has anyone used this stuff? is it as advertised?
It is a cheaper alternative to the auto rx maintenance dose of 4 oz between intervals.quote:
Originally posted by crimsontide:
does it clean as good as auto rx??
Unfortunately, I have this issue only on one car, others consume some oil. On the one I add it only when I change the filter at the 6 month interval as I agree, unless you drain a few ounces you will be overfilling.quote:
Originally posted by elwaylite:
One thing that bothers me about the LC process, is the dosage. You add this every so many miles, but then it says plain on the site not to overfill crankcase. If you're full when you start and dont burn any, arent you overfilling? I'm planning to use LC but this has been bugging me since i read it.
