LSJR shows how boost impacts your oil
Virginia
I'd say this is similar to what I have seen with fuel dilution/viscosity drop and why when upping the power on a boosted engine looking at the oil you use and used oil analysis is important. My Sportwagen makes peak ~22 psi and is >200hp/liter. Good video/data here.
I want to start off by saying that I really like that LSJ is doing videos like this that are different than the other oil videos online. It was an interesting video but I would also like to see the same test done with an engine for a regular street driven car as opposed to a 1300hp drag engine. For instance, maybe take a car that already has a turbo on it, and then add a lot more boost to the same setup and see what happens to the used oil analysis. I'm sure it would also show that stepping up to an oil with a higher HTHS would be better though.
And that brings me to another point, it would be nice to see that kind of test between two oils of the same viscosity, but one of them has a lower HTHS than the other. Example, vanilla Mobil 1 5w30 with it's 3.1 HTHS and Mobil 1 ESP 5w30 with it's 3.5 HTHS.
You can look at TiGeo's UOA for the first part
Unfortunately I don't have a pre-tune baseline buy do have stage 1 which upped boost on stock turbo to about 18psi if I remember correctly then to the upgraded OE turbos both at 22psi. I have used oil analysis since new/5.5 years/100k miles full charts/graphs.
