I'm currently running Motorcraft Mercon V in my 4R70W, and keep an eye on fluid temperature constantly through my ScanGauge-II. Usually it's been within the 150-170 range since I started keeping an eye on it in February.
As the weather's started to warm up (104 - 122 F range), I've noticed the transmission fluid temperature's now started creeping into the mid to high 180s, which is a bit high for my liking. The vehicle's equipped with a factory ATF and power steering fluid cooler, but the average is still 180 F.
I'm due for a ATF change in about 3,000 miles, during which I drain the torque converter and drop the pan to replace the filter. Takes about 13L to refill, which is its fluid capacity.
I'm considering switching over to Liqui-Moly's Top Tec 1200 ATF, which is a multi-vehicle fluid comprising of Group III basestock officially meeting Ford's Mercon V spec. I'm just wondering if the Group III basestock will help lower ATF temperatures. Is there anything else I can do to keep it in the 170-180 F range? Thanks!
