Low oil with new G6 & Castrol
Originally Posted By: GMFan
You used 1/2 quart of oil in ~4k miles. That's completely normal. I know folks with dogged out engines that burn a quart every 300 miles.
Either way, the 2.4L Ecotec will outlive the rest of the car. No need to worry, they're great engines. Just check your oil every other fill-up of gasoline and top-off as needed.
BTW, 10k miles on the factory fill probably wasn't the best idea.
1/2 qt useage may be not be a problem but I don't think it is a good thing.
If an engine burns a qt/300mi it is not dogged out. It has leaking valve seals and needs fixed.
FWIW I have had oil consumption in every vehicle I have used GTX in. I switched to another brand and it went away.
example:
OCI before GTX (any brand dino)-no consumption
OCI with GTX-oil consumption
Next OCI (any brand beside GTX)-back to NO consumption
I would change brands. IME an engine will consume Castrol GTX and not other brands.
Well I'm keeping an eye on it and will not go over 10k, regardless of OIL METER % left. Next time I will go with another dino brand.
Does anyone have the GM Dino list of approved oils? for the 5w30 spec?
