yes. internal leakage in the pump stays the same regardless of rpm and bearing oil consumption likely drops at higher rpm. in any case, double pressure doesn't mean double oil flow through bearings or spray nozzles.
Drop rpm below 400 or so and the oil pressure light might flicker...
