Originally Posted By: Lubener
Originally Posted By: Spetz
I installed an oil pressure gauge and at idle with warm oil it sits at 15psi.
The engine is a rebuilt 6A12 Mitsubishi.
Oil pressure when cold is high (55psi or so) and when revved warm it goes to 150psi.
I understand the high pressure could be the pressure relief valve but what is the low idle pressure attributed to?
I would check the accuracy of your gauge. I doubt your reaching 150 psi.
Yeah, I'm in this camp. 15 PSI hot idle is fine with me. No work being done, engine just loafing. As long as no noise like lifter tick, no biggie.
150 PSI is way to high to do any good, and indicates that the pressure relief is not working... Should not see anything over 10PSI per 1,000 RPM, or the system is not right.
