This is the scenario:
I am going to be doing some performance work on my 2002 T/A. Being installed is the performance cam/valve springs, timing chain, ported oil pump. I have Redline oil in the sump.
I had intended to change the oil after my swap, but really, the oil has less than 600 miles on it because I didn’t drive the car over the winter. I’ve got practically clean oil in there!
I know that late-model roller cams like those in the GM LS1 don’t “break-in” like the old non-roller varieties, and you don't use an "assembly lube" on the lobes or bearings.
But I’m still wondering about my metals content being high in the oil and about the occasional piece of small dirt from opening the valve covers, front cover, etc.
What are my options?
Should I just change the filter & add another quart after the engine’s been run a bit?
Or
Should I go the expensive route and dump this oil/filter and put all new in?
Or
