I have an 06 mustang GT with the 3v 4.6L SOHC. Currently using Pennzoil Platinum 5w-20.
1100 miles ago, about 2 months back, the oil was changed. Had Mobil 1 5w-20 in there before.
When I last changed the oil I checked the level after adding 6 quarts and it was 1/2 way between the two dots. I topped it off and got it up to the top dot.
I checked it last night and noticed the level seems to have crept down a small amount. Approx 3mm from the top dot. Now it is about 3/4 up between the two.
Is there a problem? Engine doesn't leak or burn that I can tell visually. Only has 11,000 miles.
