Longer filter for a PF48
Cross those numbers to WIX ...pay attention to bypass valve settings ..and even whether it has one or not..ADBV ....gasket sizes ..etc..etc..etc. Item Number Item Description Attribute Description Attribute Value P502048 LUBE SPIN-ON FULL FLOW A - OD (Inches) 3.54 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 3.18 D - Gasket OD (Inches) 2.52 E - Gasket ID (Inches) 2.27 Product Type Description LUBE SPIN-ON FULL FLOW Primary Application HONDA 15400-PA6-305 Product Group FL P502072 LUBE SPIN-ON FULL FLOW A - OD (Inches) 3.64 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 5.47 D - Gasket OD (Inches) 2.75 Product Type Description LUBE SPIN-ON FULL FLOW Primary Application MOTORCRAFT Product Group FL P550166 LUBE SPIN-ON A - OD (Inches) 3.67 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 5.42 D - Gasket OD (Inches) 2.83 E - Gasket ID (Inches) 2.46 Relief Valve Setting (PSI) 17-22 Product Type Description LUBE SPIN-ON FULL FLOW Primary Application ONAN 122-0550 Product Group F P550357 LUBE SPIN ELMNT A - OD (Inches) 3.78 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 3.78 Relief Valve Setting (PSI) 10-15 Anti Drain Valve (Y/N) Yes Product Type Description LUBE SPIN-ON FULL FLOW Primary Application FORD 844F6716AA Product Group F P550389 LUBE FILTER SPIN-ON A - OD (Inches) 3.15 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 3.94 D - Gasket OD (Inches) 2.48 E - Gasket ID (Inches) 1.99 Relief Valve Setting (PSI) 8-11 Anti Drain Valve (Y/N) Yes Product Type Description LUBE SPIN-ON FULL FLOW Primary Application ISUZU 8941145840 Product Group F P550600 LUBE SPIN-ON A - OD (Inches) 3.15 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 3.17 D - Gasket OD (Inches) 2.94 E - Gasket ID (Inches) 2.43 Product Type Description LUBE SPIN-ON Primary Application HONDA 15400PL2004, 005, 305 Product Group F P550794 LUBE SPIN ON A - OD (Inches) 3.00 B - Thread Size (Inches) M22 x 1.5 C - Length (Inches) 3.26 Relief Valve Setting (PSI) 20 Product Type Description LUBE SPIN ON Primary Application GM 2007 LIGHT TRUCK Product Group FL P550965 SPIN ON LUBE A - OD (Inches) 3.67 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 3.58 D - Gasket OD (Inches) 2.81 E - Gasket ID (Inches) 2.42 Relief Valve Setting (PSI) 15 Anti Drain Valve (Y/N) Yes Product Type Description LUBE SPIN-ON FULL FLOW Primary Application FORD LIGHT TRUCK Product Group F P553315 ELEMENT, LUBE SPIN-ON A - OD (Inches) 3.82 B - Thread Size (Inches) M22 X 1.5 C - Length (Inches) 5.51 Product Type Description LUBE SPIN-ON FULL FLOW Primary Application FORD 785F-6714-AA3A Product Group F
Hi all, first post here. I recently bought an 08 Saturn Outlook which uses the PF48. I'd also be interested in finding a longer filter that is otherwise equivalent to the PF48. Below are the specs for the Wix 57060, which is their match for the AC Delco PF48. None of those in the previous post look like they match very well. If anyone finds anything suitable, please let us know. http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=57060 Part Number: 57060 UPC Number: 765809570603 Principal Application: Various GM, Saturn, Saab (07-10) All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.430 Outer Diameter Top: 2.970 Outer Diameter Bottom: Closed Thread Size: 22X1.5 MM By-Pass Valve Setting-PSI: 15 Anti-Drain Back Valve: Yes Beta Ratio: 2/75=10/25 Max Flow Rate: 10-12 GPM Nominal Micron Rating: 21 Gasket Diameters Number O.D. I.D. Thk. Attached 2.750 2.410 0.270
That's only under the assumption that WIX has the closest to OEM spec's (a fairly reasonable assumption) This is the Donaldson x'ref to the 57060 P550794 LUBE SPIN ON A - OD (Inches) 3.00 B - Thread Size (Inches) M22 x 1.5 C - Length (Inches) 3.26 Relief Valve Setting (PSI) 20 Product Type Description LUBE SPIN ON Primary Application GM 2007 LIGHT TRUCK Product Group FL
Good point Gary, thanks. I can't find the actual specs for the PF48. Below are a few more x'refs. The relief valve pressures vary more than I expected. Purolator PL12222: Anti-Drain Back Valve Yes Height 3.34 O.D. 2.95 Relief Valve P.S.I. 12-15 Threads M22x1.5 Fram PH10060: Anti-Drain Valve YES Product Height 3.33" Product I.D. 22mmx1.5mm Th'd Product O.D. 3" Relief Valve Setting PSI 9-12 Baldwin B160: Contains: Anti-Drainback Valve 20 PSID By-Pass Valve Thread: M22 x 1.5 O.D.: 3 (76.2) Length: 3 1/2 (88.9) K&N HP-1017: Height: 3.74 in (95 mm) Outside Diameter: 2.98 in (76 mm) Thread Inside Diameter: M22x1.5 PSI Relief Valve: 11-17 Anti Drain Back Valve: Yes
They appear to fall into a somewhat higher than typical bypass valve levels ..except for Purolator. 12-16+/- is their standard deal. What about this? It doesn't show an ADBV in WIX.... Part Number: 51592 UPC Number: 765809515925 Principal Application: Cummins, Komatsu, Onan Engines All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 5.214 Outer Diameter Top: 3.663 Outer Diameter Bottom: Closed Thread Size: 22X1.5 MM By-Pass Valve Setting-PSI: 18-20 Burst Pressure-PSI: 250 Max Flow Rate: 11-13 GPM Nominal Micron Rating: 19 Gasket Diameters Number O.D. I.D. Thk. 15614 2.834 2.462 0.255 ....but this filter does in Baldwin B281 Descriptions: Full-Flow Lube Spin-on Contains: Anti-Drainback Valve 20 PSID By-Pass Valve Fits: Komatsu, New Holland Equipment; Onan Generators; VM Engines Replaces: Onan 122-0550; VM Engines 4115030 Thread: M22 x 1.5 O.D.: 3 11/16 (93.7) Length: 5 3/8 (136.5) I. Gskt.: G381-A UPC: 7 91440 00343 9
