95 Cutlass Supreme with 3.1 L V6. 143k miles.
I plan on a 20 hour road trip in a month. Leaving Cleveland ambients ought to be around 60, then spending 10 days in FL where it ought to be low 80's.
I have only a few hundred miles on the Valvoline MaxLife 10W-40 in there. I have tried Mobil 1 5w30 or 0W-40 in this engine and get a lot of noise, so especially in the summer the 10W-40 seems to work really well.
Car runs pretty good. Idling in traffic for long it heats up and the fans kick on, pretty normal it seems. Running on highway I see 192 all day.
But around here the highways are flat. In KY and TN I'll be seeing some long, steep grades. Would you add any moly, through some Valvoline Synpower treatment?? Would that help keep temps down and power up?
Also, I was going to run an UOA on this oil when I got back. If I add VSOT will that throw off the numbers and screw it up?
For the winter I will go back to either 0W-40 or 5w30 Mobil 1, or perhaps a mix of those two since Mobil 1's 30 weight is so light.
Thanks
Brian
Thanks
Brian
