Here is some live data from my Saturn's onboard computer.
The vehicle is a 96 Saturn SL2 with 143,000 miles. The Thermostat is a 195F unit. I currently have a mix of 11 gallons Costco 91 octane fuel and 2 gallons 87 octane in the tank, if that matters. There is also a few ounces of Amsoil PI left in the tank as I have just finished a treatment.
I am confused as to why the spark advance is in the negative. More specifically, why I have 14 degrees of negative spark advance at idle. Is this normal? Or is it something bad? Could it be due to the high octane fuel I have in the tank? The car specs 87 octane, but I am running 91 as a test.
Also, in my OnDemand5 reference source it shows that for Oxygen Sensor testing, 0.1 volts equals lean and 1.0 volts shows a rich condition. Mine is showing 0.270 volts, so is that good or bad?
And for the STFT B1 value-- is that the long-term fuel trim?
Thanks.
Thanks.
