Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 2,657
I had a Aukey PB-T4 10,000mah power bank that recently started smoking while I was charging my phone.
I hear a little crackle, look around, and then see smoke rising from under the power bank. Just a little wisp of smoke, just as much smoke as when you put out a candle. I pick it up, pull out the usb cable and running towards the patio to toss it onto the lawn I notice a hole melted through the exterior plastic by the USB port with what appeared to glowing red piece of metal. I wish I took a picture of it, but we disposed of the unit quickly. Taking the load off by disconnecting the USB cable reduced the smoking and it completely stopped in the grass.
I was flying the day before while also using the same power bank in my briefcase. Man that would have been an incident.
This makes me wonder, should we dispose of old power banks? Do they age out or maybe they can't be trusted any longer with time?
I purchased in 2016, it is no longer available on Amazon: "AUKEY 10000mAh Portable Fast Charger with Qualcomm Quick Charge 2.0 for Smart Phones - Black
AUKEY"
BTW that little wisp of smoke stunk up the room pretty bad, a chlorine type smell, that didn't go away after a day of 3 fans running non stop. All materials nearby were run through the laundry twice. I think the carpet absorbed a lot of the smell. The room needs to be repainted and hardwood installed anyway, so hopefully that fixes everything.
AUKEY"
