wemay
Site Donor 2023
http://www.liqui-moly.com/liquimoly/web....&redirect=1
MINERAL MOTOR OILS
Motor oils are conventionally made from mineral oils. In view of the increased demands for extended intervals between oil changes, high
engine performance and low friction properties, etc., the performance of these oils is limited. Typical viscosities are: 10W-40, 15w40 and 20W-50.
HYDROCRACK (HC) MOTOR OILS
Hydrocrack oils are mineral base oils which have been further processed at the refinery using elaborate methods. They also contain a small proportion of synthetic components. Typical viscosities are: SAE 5W-40, 5w30 and 10W-40.
PARTLY SYNTHETIC MOTOR OILS
These are mineral oils with synthetic components. They improve the coldstart properties, keep the engine clean and provide outstanding wear protection. Typical viscosities are: 10W-40 and 5W-40.
FULLY SYNTHETIC MOTOR OILS
Valuable Synthetic fluids are the basis of up-to-date high performance motor oils. Fully synthetic motor oils can be used for gasoline and diesel engines, provide excellent oil delivery during cold starting and optimum wear protection, have friction-reducing properties and keep the engine outstandingly clean. They frequently comply with the highest quality standards of the API, ACEA and companyspecifications. They are particularly suitable where there are long intervals between oil changes. Typical viscosities are: 0W-30, 0W-40 and 5W-40.
MINERAL MOTOR OILS
