I use Ceratec in my transmission with good results. I have tried it in the motor too with ~ a 2 mpg improvement. I have not seen it settle out in the trans oil when changing it.
They also sell "MoS2 for gears" for manual trans/gear boxes/diffs etc.LM has a product dedicated for transmissions named 'Gear Protect'. IF I'd add anything in my transmission again, then I'd get exactly that one. Quite recently I tried Eurol Engine Treat (which I still think is an excellent add for engine oil) in my Mini Cooper's manual transmission and it clearly made things worse. And that's with just a tiny amount (50 ml or so). Synchronizers seems to have a hard time due to loss of (required) friction. Eurol Engine Treat contains AN and W (tungsten).
Btw, to get 2 mpg improvement from just transmission oil you'd have to run a much much thinner oil. No additive will give you that improvement. I doubt you did a real test in a controlled environment.
https://m.media-amazon.com/images/I/81y-osynu7L._AC_SY879_.jpgI don't see anywhere in the product info or the bottle where they say stops lifter/lash adjuster noise instantly. I do see this though.
You just added white graphite to the oil, a solid. Frankly I think it is a little silly to use any product and expect instant results, if you would have said a whole oil change and now used something else and it is quieter then maybe your little test may have more validity.
It says: "LUBEGARD works immediately to form superior long lasting lubrication to all surfaces of your engine." Nowhere on that label does it say it addresses lifter/lash adjuster noise, or any other noise for that matter.https://m.media-amazon.com/images/I/81y-osynu7L._AC_SY879_.jpg
First paragraph. It says it works immediately.
Yep, which implies it should work instantly. Which it clearly didn’t work instantly. One clearly works instantly while the other doesn’t.It says: "LUBEGARD works immediately to form superior long lasting lubrication to all surfaces of your engine." Nowhere on that label does it say it addresses lifter/lash adjuster noise, or any other noise for that matter.
Work instantly at what? It appears like you were hoping for something that wasn't stated on the box you linked to, for it to silence a mechanical issue which no such claims were made. I'm sure it formed superior long lasting lubrication to all your engine surfaces, just like the box said.Yep, which implies it should work instantly. Which it clearly didn’t work instantly. One clearly works instantly while the other doesn’t.
Work instantly at reducing friction. I mean it is a friction modifier, so it should do something. Clearly it didn’t. It claims to do other things on their website... https://www.lubegard.com/products/biotech/Work instantly at what? It appears like you were hoping for something that wasn't stated on the box you linked to, for it to silence a mechanical issue which no such claims were made. I'm sure it formed superior long lasting lubrication to all your engine surfaces, just like the box said.![]()
And where does it say instantly in that text? You linked to the box, the box stated what it does instantly.Work instantly at reducing friction. I mean it is a friction modifier, so it should do something. Clearly it didn’t. It claims to do other things on their website... https://www.lubegard.com/products/biotech/
“YOU SHOULDN’T START YOUR CAR WITHOUT IT!
FOR USE IN GASOLINE AND DIESEL ENGINES INCLUDING THOSE ENGINES WITH DIESEL PARTICULATE FILTERS
- Reduces oil and fuel consumption!
- Optimizes engine horsepower and performance
- Protects and extends oil life by 30%
- Improves fuel economy by reducing friction in your engine
- Reduces wear on metal components, thus increasing part life
- Improves anti-friction and anti-wear properties of ALL major oil brands to meet requirements of ALL vehicles, including older and high performance models
- Eliminates lifter and other objectionable noise on startup, especially in cold weather
- Ensures smoother running engines
- Reduces hot engine oil temperatures
- Gives improvement in friction and wear performance over major brands of motor oil
- Blends with ALL motor oils currently produced, including API; SJ, SJ/EC, CG- 4, CH-4, SE, SF, SG, SI, CC, CD, CE, SL, SD, SM, CF and SN motor oils
- Helps reduce smoking by restoring flexibility to valve stem seals for improved sealing, also providing outstanding upper cylinder lubricity as it frees up sticking rings
- Inhibits oxidation and extends engine oil life (see TFOUT test results below)
- Also use to extend the life of small 4 cycle engines such as; lawn maintenance equipment, motorcycles, snow mobiles, etc.”
It doesn’t say instantly anywhere on that webpage I linked. Not a problem. I can hear which one works better at reducing friction already, and I won’t be running lubegard in the future.And where does it say instantly in that text? You linked to the box, the box stated what it does instantly.
FTR STP and Lucas Oil Stablizer could have quieted your engine too. You're not happy with the product that's fine, but you took the text completely out of context.
Try calling them up, tell them what you did, how long you ran it and your concerns, let them sort it out.
How can you hear a reduction in friction? That’s not what a reduction noise means in your instance.It doesn’t say instantly anywhere on that webpage I linked. Not a problem. I can hear which one works better at reducing friction already, and I won’t be running lubegard in the future.
I actually tried lucas oil stabilizer, and it didn’t do anything either.
Seriously? Lower noise levels means less friction.How can you hear a reduction in friction? That’s not what a reduction noise means in your instance.
If your engine was so on the edge with “friction” that this additive corrected it, then you’ve got something seriously wrong with that engine.
So vibration shock that causes the knocking or tapping you’re hearing is friction that’s reduced by the additive?Seriously? Lower noise levels means less friction.
My thoughts exactly. My bet is Ceratec masked the problem, it didn't instantly fix it. If I cared for the vehicle I'd diagnose and repair/replace the parts at fault.How can you hear a reduction in friction? That’s not what a reduction noise means in your instance.
