This sample was in service for 500 hours with no oil consumption. I felt it was in service a bit long and asked one of my supervisors to have the
oil changed
Cu-3
Fe-47
Cr-1
Pb-8
Al-4
Si-3
Moly-80
Ca-2524
P-1045
Zn-1231
Water-0
Antifreeze-0
St-80
Oxi-50
Sul-68
Nit-60
PQ-29
Vis-15 cst at 100 C
Some numbers are high but the wear metals are good. This is bulk BP oil from a local oil company. We buy it for about .90 cents a quart. This lift is operated at a lumber dry kiln facility. It runs 16 hours per day. This is a turbocharged six cylinder perkins diesel with 10000 hours on a major rebuild. The motor lasted about 20,000 hours before the rebuild. It is rated around 180 horsepower.
oil changed
Cu-3
Fe-47
Cr-1
Pb-8
Al-4
Si-3
Moly-80
Ca-2524
P-1045
Zn-1231
Water-0
Antifreeze-0
St-80
Oxi-50
Sul-68
Nit-60
PQ-29
Vis-15 cst at 100 C
