Light switch only works in the middle
It's probably arcing and ready to start a fire in the middle position...I am dead serious.
If this is a house switch, why is it in the maintenance forum?
Originally Posted By: motor_oil_madman
Does that mean it's worn out or did somebody not wire it right?
Worn out. Almost impossible to miswire a single pole switch.
Replace ASAP.
ZZZZZZZZZZ!
Originally Posted By: KJSmith
Less than $5.00, less than 10 minutes.
Replace it.
What part of Houston?
A single pole switch can be had for less than $1 at pretty much any store. Just replace it.
There should be a home repair forum for these questions.
If it's one that is frequently used or carries a large electrical load don't use the $0.59 ones.
Replace ASAP.
you have not met me lol
This should be moved to the General and Off Topic Forum.
