For various reasons, I'm feeling compelled to try and remove the 4.2 V6 engine from my F150 to properly fix some issues that have been nagging for a few years. Truck is a 2002 and about to turn 150K miles in a few weeks.
1. Engine mounts are old and dried. Already have replacements but I couldn't change them out with the engine in the truck.
2. These trucks are notorious for oil pan gasket leaks. Factory pan "gasket" is a sloppily applied RTV with a half-circle silicone piece for the front of the pan. The crossmember doesn't unbolt so you HAVE to remove the engine to service the pan.
3. These trucks also seem to have oil leaks from the cylinder head gasket toward the rear of the engine. The oil all over the starter and back of the engine would indicate that is the case with my truck.
4. The IMRC actuators at the BACK of the engine have plastic bushings that wear out and eventually you get stuck with an OBD code for "IMRC Runner stuck open". Mine still seem to be attached but most don't last this long.
5. I plan on putting in a new thermostat and new radiator hoses. This would be a LOT easier with the engine out.
6. I'd like to pull the valve covers and see how the internals are. I've got some new valve cover gaskets waiting for this reason.
Honestly I can live with the worn mounts, do the radiator and tstat work with the engine in place, and I am going to try some ATP AT 205 on the next oil change to see if it helps the oil leaks.
The rest of the truck is fine and I'd rather get another 3-4 years out of it if I can (in that time I can save up for the down payment on my dream car).
Am I going overboard if I plan on lifting the engine out? I've never done this level of work before.
