Lifter tap 1999 GM 6.0L
Originally Posted By: jazeo
Read it again
Originally Posted By: daman
He said just BELOW 40 to the right of the 40 mark.
depending on oil temps yes around there.
I must be looking in the wrong place I don't see where he says below 40..
At any rate he needs to hook up an aftermarket gauge and check it, at operating temp(hot)40 is not spot on with 30 weight oil.
It's way high.
Originally Posted By: hisilver
With the proper six quarts the operating temp oil pressure at idle is just below the 12 oclock position, which i think says 40, i will have to check that number. My 5.3 takes six qts also and the oil pressure guage acts identical.
Your pressures are spot on nothing wrong with it thats where they run on these trucks with the factory 5w30.
Are you saying the gauge is accurate and 40psi @ idle is spot on for those trucks with 5w30 ???
12 oclock on these trucks is 40psi
ok sorry, so the 12:00 position says 40, but even 30(hot)is on the high side and I think if he goes to 40 weight oil it will be way too high. I still think the gauge is inaccurate and it's not that high.
totally agree with the piston slap diagnosis. its the nature of the "vortech" beast. my 2000 4.8l slapped from 75000 until i traded it @ over 100,000 miles. it still ran perfect with no consuption or smoke.
i also agree that your engine will run forever slap or no slap. its just annoying. the best oil i found for my truck was valvoline durablend 5/20. it seemed much more quiet.(not sure why??)
I agree with you a 40w is NOT needed.
Ok, so I cant see where people are saying just below the 40 mark is too high of a pressure at operating temp idle. Ive driven and owned several 6.0, 5.3 GM V8s and they all read like this. Even if all the Oil pressure guages were innacurate, forget the numbers on the dash and understand the needle movements are all very similar wether hot idle, cold start up, acceleration, whatever.
Not trying to start a war here but this is how it is. Anyway, the truck in question consumes very little, and has no oil pressure isssues. The guage has acted just like this for its whole life. So i guess this is just piston slap arriving in its golden years. I will let it live out its life on 5w30. I want to get my hands on the 6.2L anyway!
I'm not saying that at all,i've owned many GM trucks we have them at work also and they all read like that,depending on the oil temp as i stated before.
GM vehicles always have good oil pressure.
