Originally Posted By: Onmo'Eegusee
09 Hemi, probably uses a Wix 51372? If so, try a Motorcraft FL820S from WalMart.
They look virtually identical except for height
Part Number: 57899
UPC Number: 765809578999
Principal Application: Various Dodge, Chrysler, Jeep (08-09)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.740
Outer Diameter Top: 3.675
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM 6-H
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.815 2.480 0.175
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-09), Mazda (00-09), Cadillac STS-V, XLR-V (06-09)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.668
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Gasket Diameters
Attached 2.834 2.462 0.200
