Originally Posted By: camrydriver111
Awesome. What year?
I wonder how much parts cost.
My post from: "How reliable or unreliable are your vehicles?" -
"I'm going to skip warranty claims as they were growing pains, and they show no charge any way. I'm the second owner, the original owner had it serviced at the same dealer since new.
2004 VW Phaeton V8, excluding wear items and warranty claims, here it goes:
62,785 - 21 SEP 2009 - $60.15
. Rear sun shade switch trim replaced
72,626 - 19 APR 2010 - $559.66
. No start caused by break in wiring harness behind telescoping steering wheel.
88,570 - 05 MAY 2011 - $1122.93
. Replace wheel housing liner/low speed fan making a noise and speed below specification.
96,850 - 06 DEC 2011 - $477.80
. Replace window regulator.
106,811 - 22 OCT 2012 - $311.85
. Right rear quarter glass sunshade damaged.
110,691 - 01 FEB 2013 - $492.40
. Replace both front tweeters
112,314 - 18 MAR 2013 - $3561.15
. Replace front upper and lower guide links, upper wishbones, mounting brackets and sway bar links. Replace rear suspension upper links, lower links, and sway bar links.
114,436 - 04 SEP 2013 - $727.00
. Replace TPMS controller
114,771 - 18 SEP 2013 - $2945.54
. Engine out service for replacement of oil cooler union.
128,923 - 20 OCT 2014 - $1774.17
. Replace rear glass to correct defroster concern/replace drivers mirror for motor failure
130,705 - 19 JAN 2015 - $2482.61
. Right headlight adjuster failure. Replace left and right headlight, headlight washers, and all bulbs per customer request.
Obviously with wear and tear items such as brakes, tires, oil changes, etc the number would be high. This car has had every service performed on time or ahead of schedule.
Since taking ownership , I've done one DIY oil change and a paint correction. I have another oil change as well as a transmission and differential service lined up for my next trip home.
All systems are functioning as designed."
I love the car!
