I posted this on another forum but I thought I would post it here as well:
This weekend I finally had a chance to do some shooting with the Weapon Shield. I used a stainless Ruger MKII .22 pistol as test bed because 1: ammo is cheap
and 2: the gun gets dirty quickly. I fired ~700 rounds of plated ammo in about 1 hours time. The gun is now quite dirty (looks like mud inside), but the oil is still wet and the gun is working fine. I only had 3 stoppages. One was a bad round (would not fire) and the two others were magazine related (not getting the round into place fast enough).
I have not cleaned the gun (I'm counting on your inhibitor package George
) or added any WS and will try to shoot it again next week and see how many rounds it takes to start getting problems. This gun usually has stoppages after ~500 rounds due to dirt caking on the breach and not allowing proper chambering, so it is already ahead of the game. I did notice some caking starting to form though. Once it starts failing, I'll try just adding some WS and see if it helps.
When I first applied the WS to the gun, there was some carbon buildup around the crown from when it had been fired before. The WS took this right off with only a paper towel, and there was no build up on the crown at all after the firing session. I should add that this stuff sticks like crazy and is even hard to get off with a clean paper towel.
So far I am very impressed with this product.
I also used some of bruce's grease on on the slide rails of my Sig P226 (aluminum frame). It goes on easy and sticks very well. It did not seem to slow down the slide like most greases do (which I hate). It also nearly turns back to an oil with very little build up. I will keep it on there and see how it does. Maybe I'll lube up my other MK II with it and do a similar test as above to see how it holds up.
