Hydrotreated Heavy Naphthenic Petroleum Distillates & Pine Oil
"BG Engine Purge is not an ordinary engine flush. It is an effective blend of solvents and dispersants which will quickly and safely remove
accumulated sludge and other deposits from the engine. It can actually restore compression by removing soot and deposits from around the
rings; hence, the compression rings seal in compression gases. BG Engine Purge does not contain harmful chlorinated solvents. It may be
used in gasoline, diesel and rotary engines."
MSDS
MSDS
