A aaxb970 Joined Aug 27, 2008 Messages 366 Location Cambridge. Ontario, Canada Nov 8, 2009 #1 Hi All....had a leaky "o" ring on my return transmission line....during the process of changing it this morning I lost 300 ML of fluid being Dexron VI.....could I use the Mercon V I already have opened to top this minimal bit up ? Thanks...
StevieC Joined Aug 21, 2008 Messages 25,104 Location ON, Canada eh? Nov 8, 2009 #2 Does the engine specifically call for VI or is V ok to use? If the manual says V is ok then it's fine... Otherwise I wouldn't put it in there.
