Elkins45
Site Donor 2026
I don't think that's it. it's not closing too soon, it's just not very powerful.That can happen when the chain is too long and it’s not opening the flapper fully.
This is the one I used:I've bought Fluidmaster and Korky parts just based on what store I ended up at. I'm 99% certain Fluidmaster includes that clip.
The embedded video in the Home Depot link for the Fluidmaster PerforMAX fill valve you posted shows how to attach the refill tubing to the included plastic clip at the 1:51 min. mark.
If Korky is good enough to be OEM supplier for Toto, that’s all I need to know.I always used Fluid Master fill valves and Korky flappers. I have a Kohler which I have had leakage using Fluid Master flappers, problems ended by using a Korky.
That kit includes the clip
Older video, but enough evidence for me to permanently discount installing a pressure assisted toilet.And exactly the reason for replacing our most used toilet with an American Standard pressure assist toilet. Just make sure the flange seal is sturdy enough to handle the increased flush pressure.
Wow I did not know how far toilet tech has come! It's all about water conservation and parts profit now.There are a lot of weird flappers out there now. I've got an American Standard toilet with a 3" Fluidmaster 510A flapper. It's all hard plastic except for the silicone sealing ring. Kohler used some really bizarre ones, like the shark fin and one that has a foam disc inside the flapper. Some toilets use a flush tower now.
It might be really tough to find any new toilets with a traditional 2" flapper that would have previously been the "universal" size. They mostly use wider flappers that allow for water to enter faster, but then rigged to allow less water use. My 1.3 gallon per flush toilet works great. The tank might hold about 3 gallons, but the whole thing is meant to only dump about 1.3 gallon each time. Part of it is the greater potential energy from the top of the water level being higher.
