Leaky freeze plugs and coolant system sealer
they list what it fixes they forget to add additional benefits.. like
"clogs heater core"
"clogs radiator"
I had a Suburban w/a leaker that was VERY hard to get to (SB 350, back of the engine behind torque converter)-Bar's Leak slowed it down, but wouldn't stop it completely, didn't hurt my (admittedly new) radiator a bit. Used conventional green A/F, couldn't get the time to pull the transmission to save a couple bucks on antifreeze!
It will probably work... but my concern is that you have a paper thin corroded like swiss cheese core plug down in there and that it will eventually blow out completely while the system's pressurized. Most likely on a Sunday when you're 300 miles from home...
