My 97 Dakota has been sitting in front of the house for a couple weeks because of a problem with the steering knuckle. While it was sitting there it started bleeding transmission fluid all over the driveway. In less than a week it's leaked down to the point where the fluid doesn't even show on the dip stick. It's definitely coming from a hole in the pan. It looks like a previous owner tried to repair the pan with JB weld and the JB weld has failed. I guess it must have been a fairly successful repair though because I've owned the truck for seven years so it's been holding for at least that long. So with that in mind I'm trying to decide. Do I just try to patch it with JB weld again or go ahead and fix it right with a new pan. The pan seems to be a little hard to get. I managed to find a couple on ebay for about $80 and a Google search turned up a "universal fit" pan on JC-Whitney for $35. But I'm not to confident about a "universal fit" so I'm thinking that's probably not an option I should consider.
I'm leaning toward just doing it right and getting the OEM pan on ebay but a JB fix is pretty tempting on a sixteen year old truck. If it would hold for another seven years that would probably do the trick.
Thoughts?
Thoughts?
