2008 Chey Avalanche 2WD LT
5.3L iron block flex fuel engine
LE 8130 Monolec Ultra Blend 10W-30 HDEO (second fill). Valvoline WB had been regularly used before the LE 8130.
Pure One PL12222 oil filter
OEM air filter
Fuel...who knows, it's my daughter's truck. LE LX 2300 added when I get a chance.
Driving style is mixed.
The truck is stock.
I'm not sure where all the Na is coming from. It doesn't seem to be coolant. It is more than I usually see in 8130. Bearing/bushing wear seems high, but I'm used to the Toyota 2UZ-FE and the Honda F22C1.
I've been trying to lengthen OCI's on this vehicle. But I kept seeing crud and casting materials in the bottom of the drain pan for the longest time!
I've also been monitoring what appeared to be a oil pan gasket seep. Now, the lower back of the engine is wet, but not dripping. I cleaned it up with some brake cleaner, but need to bring it back home to have another look. There is a steering rack in the way though. I might have to take it to a shop if I can't see exactly what is leaking.
Code:
Valvoline 5W-30 Monolec 10W-30
SN/GF-5 CJ-4/SM
5/18/2011 11/17/2012
OLM 47% OLM 27%
55,511 miles 78,500 miles
4,628 miles 6,107 miles
Dyson (MRT lab) Polaris-Houston
Iron 12 11
Copper 37 40
Tin 0 1
Lead 13 13
Chromium 1 2
Nickel 0 0
Aluminum 1 2
Titanium 0 0
Silver 0 0
Cadmium NA 0
Vanadium 0 0
Calcium 1599 1174
Magnesium 10 970
Zinc 787 1263
Phosphorus 563 1008
Barium 0 0
Molybdenum 6 49
Antimony 0 0
Silicon 14 13
Sodium 89 140
Boron 7 1
Potassium 0 0
Manganese NA 2
Lithium NA 0
V40C cSt 56.0 NA
V100C cSt 9.4 11.7
Viscosity indx 151 NA
TAN 2.23 NA
TBN 1.7 3.41
Flash Point 355F NA
Oxidation 16 19
Nitration 10 16
KF 473 NA
Water% FTIR NA
Fuel% 0.953 (FTIR)
Soot% 0
Glycol 0 NA
Sulfate by product 23 NA
I also wondered why Polaris didn't do GC for a fuel reading. Then I found this:
Fuel Dilution %
Definition
Fuel Dilution is the amount of raw, unburned fuel that ends up in the crankcase. It lowers an oil's viscosity and flash point creating friction-related wear almost immediately by reducing film strength.
Standard Test Method Used
GC by the traditional ASTM D3524 and D3525 methodology has proven to be a time-consuming process and highly stressful on the instrumentation. FTIR has been considered a viable alternative but often requires confirmation by additional testing for flash point. An improved GC method by PerkinElmer Life and Analytical Sciences is much better at differentiating between components after separation, which significantly improves the accuracy of GC results. POLARIS Laboratories ® uses this improved GC method to confirm fuel dilution.
Reporting Measurement
Amount of Sample Needed
40 mL
Test Limitation
Because a #2 diesel fuel typically has a viscosity of around 1.7-2.1 cSt at 40°C, which is thinner than a typical 15W40 engine oil with a viscosity of around 14.7 cSt at 100°C, fuel dilution reduces the engine oil's viscosity. When the oil's viscosity varies by more than one (1) cSt from the known starting viscosity of the oil when new, we will confirm fuel dilution by the new GC method reporting the result as we do currently - as percent by volume. However, if lubricant grade is not included with the sample, fuel dilution will be confirmed by GC if viscosity is below 13.3 cSt for a diesel engine oil and below 9.8 cSt for a gasoline engine oil. If viscosity is above the oil's mid-point for the grade, fuel dilution will be reported as
OEM air filter
The truck is stock.
Code:
SN/GF-5 CJ-4/SM
OLM 47% OLM 27%
Iron 12 11
Copper 37 40
Tin 0 1
Lead 13 13
Chromium 1 2
Nickel 0 0
Aluminum 1 2
Titanium 0 0
Silver 0 0
Cadmium NA 0
Vanadium 0 0
Calcium 1599 1174
Magnesium 10 970
Zinc 787 1263
Phosphorus 563 1008
Barium 0 0
Molybdenum 6 49
Antimony 0 0
Silicon 14 13
Sodium 89 140
Boron 7 1
Potassium 0 0
Manganese NA 2
Lithium NA 0
V40C cSt 56.0 NA
V100C cSt 9.4 11.7
TAN 2.23 NA
TBN 1.7 3.41
Flash Point 355F NA
Oxidation 16 19
Nitration 10 16
KF 473 NA
Water% FTIR NA
Fuel% 0.953 (FTIR)
Soot% 0
Glycol 0 NA
Fuel Dilution %
Definition
40 mL
Test Limitation
