Lawn boy carb restoration
Texas
I have a 30 year old lawn boy that has not been run for a dozen years. I cleaned the carburetor out and replaced the float needle and the jet that it fits in. Parts #9 & 10 on the link below.
http://www.partstree.com/parts/lawn-boy/...6211-6302-8453/
It now runs (more or less), but when I turn it off, fuel continues to come up through the middle of carb (up the nozzle #12) and leaks all over.
Any thoughts on what is causing this? does the mean the cork float isn't floating? Or should I be screwing in the part #2 - Needle Adj. Is this needle adjustment for setting idle speed or some other purpose. very awkward place to have and idle adjustment screw because you can't move it w/o shutting the engine off and taking it partially apart.
I am more an expert on Briggs and Tecumseh than Lawn Boy, but I would think that with those cork floats, either it is saturated and to heavy to float, or it is binding somewhere. OR, there is a plugged float bowl vent . The bowl has to be vented, or they will run over. Many Many years ago I fought a tecumseh carb that just wouldn't stop running over, till I found the TINY bowl vent in the side of the body. Also jet #2 is the main high speed fuel mixture adjusting screw. Probably needs to be open about 2 turns+ or -
Is it the plastic carb? They will get hairline a crack when they get old and leak fuel. I would not worry about a cork float, I have seen them 50 years old and still fine
float could be adjusted too high as well, the little tab that pushes on the needle is pretty easy to bend when trying to fumble things back together.
Epilogue: First I realized that I had switched the plumbing on the fuel line and the primer lines. Then I needed to bend the float tab. Then the main jet was still clogged. Finally got it running. Thanks.
