Lacquer Primer?
For my top secret project: what kind of primer adheres very well to bare, rust-free steel? Something like Rustoleum bare metal primer doesn't adhere well enough. I want something that can be sprayed and that goes on very thin and evenly. It must be compatible with an acrylic enamel finish. Any recommendations?
I see Dupli-Color selfetching primer at Autozone. Does it adhere better than regular primer?
It adheres OK. But if the surface is flaking oxides and salt encrusted it won't work. Trying to paint oily steel?
Thanks. I have to prime some clean, rust-free steel and white metal (tin.bismuth/copper/silver alloy) pieces. I do have a phosphoric acid metal cleaner.
Linseed oil, followed by fish oil based primer is what I used on my Chevy's undercarriage.
However, in this case I need a THIN layer of primer. Ideally I'd use an airbrush.
Pablo, I think so, it's primer, might need light scuff with Scotch-Brite or such, but I've never had any problem with coatings coming loose.
Mori, the spray can type is a very thin coating, I've also used a brush on version, but it's more the consistency of house paint.
Bob
The Dupli-Color went on sufficiently thin. It seemed to adhere well enough. I did use another primer over it. Thanks all!
