Kubota only recommends 10w30 or 15w40
Thanks guys for the responses. I’m just wondering why Kubota ONLY recommends 10w30 or 15w40 and not say 5w-40.
Those are the two conventional oil choices. Historically 10w40 was only available in conventional and typically sheared out of grade in no time. Same goes for conventional 5w30.
For severe winter service, a 0Wxx might be necessary for cold starts when the machine can’t be plugged in.
In North America, we are spoiled with CK-4 synthetic options that might not be available worldwide.
I spoke too soon about not having a Kubota. I’m picking up a “new old stock” 2020 lawn tractor in two weeks.
Kawasaki 726cc, same as my X320 JD.
the recommended viscosity may depend on the outside air temp,and the severity of work conditions, most likely a good 5w-40 synthetic would be fine changed at the proper intervals.
When in Canada:
OP asked this question a year ago and is somehow hung on the word "only."
If you self educate on the winter rating of an oil, you will understand that anything that recommends a 15w40 can use 0w40.
in a kubota diesel?
Yes In several of them, and my Cat (non DPF) diesels in my sig.
My wife was a mobile pet groomer for years and an Onan 8000 (kubota D722) was the power plant in her sprinter van.
The manuals 50 hour OCI/FCI seemed way to short so I started doing used oil analysis to understand where condemnation point in that application really was.
The factory rated juice was conventional 10w30, and having had gallons of the M1 (which exceeded the factory rating) on hand for other reasons I figured Id give it a try.
Triple and even quadruple OCI hours were absolutely no sweat and I ran and serviced vans that racked up 10K hours plus on these.
Plus it has a Mercedes-Benz diesel approval.
so API CF supercedes all other C ratings......?
Man, that oil must be pretty serious stuff. Are we talking about this juice?:
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-fs-0w-40
EDIT:
Seems like you can put that stuff in everything. That might just cover everything. MB 229 is pretty stringent no?
