This is more of a curiosity question than anything else.
I was googling oil specs for other markets on the 2.4L and a few hits on "other" forums came up unrelated to oil spec..
Although 5W30 is the spec it appears in other markets - members were saying the Korean built kia's have "less" of a failure rate of the 2.4L, and even slightly over all higher quality than the USA built Kias.
Any real truth to this? I kinda believe it. The Forte has "K" as first digit on vin, and number 5, 7th to last number in vin. Both confirm it Korean built.. imho.. this Forte could give most any Honda and even some Acuras a run for its money in terms of fit and finish and overall quality. Panel gaps both inside and out are very reasonable even 9 plus years later. The feeling of the soft touch ish dash and the leather door panels inserts are out of place, and even the red stitching on the leather seats / panels is such a nice "touch".. It even has real aluminum pedals that are actually cold to the touch
.. It's just a nice place to spend some time.
The USA built Kias would have a number as first digit (1,4 or 5) than "G" as 7th digit means Georgia..
The Sonata on other hand was "assembled" in USA and although it does not have Lexus LS450 quality, it's still above class I believe for a Mid level Sonata. The 2.4L DI does not use a drop of oil and minus a couple cosmetics like the headlights are starting to fade, and clear coat that I power washed off the corner of bumper it has been rock solid reliable..
OT: Im clueless on how different markets build cars. I just assumed they all use the same parts and techniques with the same time restraints, and machinery etc.. ?
Thanks.
Thanks.
